Front grill fitting
(In Topic #232792)
Hi,
When fitting the part of the grill that goes over the headlights, are fixing clips to be used or is it just a self tapper into the front panel. Just ordering some new end pieces and noticed there are fixing clips listed but I cant see where these would fit
Thanks.
Thanks.
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
There are nylon Keepers that are on the valance, and the grille screws go in to those.
Front grill fitting
These are the ones I've found. Do you know which ones I need
knowing the year of your ride then you can go to the ETKA and get the pn, of the originals.
Can't link the etka as it appears that something is having issues.
https://volkswagen.7zap.com
Late model tintops (no idea what you have) which is all i am familiar with have 2 self tappers each side which just screw into the metal, no inserts that ive ever seen…
Re:
Re:
Mines a 81 tintop. There was no inserts when I took it apart apart but that doesn't mean alot as the car was right bodge when I got itabfmk1 said
Think replacement front panels use the later design so if its been replaced and not original you'll need the plastic inserts to screw into
Front grill fitting
Yeah it's been replaced but there arnt any large enough holes to take the inserts. I think I might try with self tapers first to save making larger holes. If that doesn't work I'll then try the inserts. Thanks for your help
