Door handle removal
(In Topic #186952)
My key is stuck in the handle
I've removed door card and the screw at side of door but handle still solid.
Am I right thinking there's a bolt it screw up inside the door?
Thank you
partsbase.org
If you remove the chrome door trim there is a screw at front I think if I remember from years ago when I took one off a mk1 Polo I think you just undo the screw in the door side and the front one and then pull the handle outwards and then the handle slides forwards or back wards and then comes out.
dont force it in case I'm wrong but the diagram might help
EDIT - just Googled up and there might not be a front screw, just remove rear one and slide forward
Last edit: by RichardHall
Cheers for link and reply
here is a how to with pictures..Vegas said
How does one remove interior handle?
Basic. Remove the door card, unbolt it remove the lever from the latch.
Forgot to include a ural.
https://volkswagenownersclub.com/vw/showthread.php/32226-How-to-remove-door-card-and-adjust-window-stop
Reversible variable Drill and left handed drill bits, Just use one that is smaller than the diameter of the head of the bolt…. going back use never-seize.
Oh, and on the new handle, take your lock out of the old one and use it for the new one.
Door handle removal
