Door handle removal
(In Topic #186952)
Sorry did a quick search first.
My key is stuck in the handle
I've removed door card and the screw at side of door but handle still solid.
Am I right thinking there's a bolt it screw up inside the door?
Thank you
Thank you
Have a look at the diagram on here
partsbase.org
If you remove the chrome door trim there is a screw at front I think if I remember from years ago when I took one off a mk1 Polo I think you just undo the screw in the door side and the front one and then pull the handle outwards and then the handle slides forwards or back wards and then comes out.
dont force it in case I'm wrong but the diagram might help
EDIT - just Googled up and there might not be a front screw, just remove rear one and slide forward
partsbase.org
Last edit: by RichardHall
Cheers I'll give it a go. Keys out so worse comes to worse it can wait and I don't need to have a Vw induced panic lol
There was a screw at front but in true be fashion it rounded off so a simple job is an git. Oh well keys out and I know what I need to do so not all bad.
Cheers for link and reply
How does one remove interior handle?
Basic. Remove the door card, unbolt it remove the lever from the latch.
Forgot to include a ural.
https://volkswagenownersclub.com/vw/showthread.php/32226-How-to-remove-door-card-and-adjust-window-stop
For removing the rounded screw.
Reversible variable Drill and left handed drill bits, Just use one that is smaller than the diameter of the head of the bolt…. going back use never-seize.
Oh, and on the new handle, take your lock out of the old one and use it for the new one.
Door handle removal
Thanks, the finger plate needed to be removed to get to interior screw. I was just being to delicate. Mine a 76 and wasn’t sure how far to push old plastic.
