DOOR GLASS STUCK IN DOOR
(In Topic #224050)
Rear is similar remove window winders any over lapping trim covers and pull.
On the drive
Myvalver 89 GTi Grey mk2 16v
If its rotted you'll need to get a replacment before you can fix it.
See at the bottom of the glass in the link;
Volkswagen Golf Mk1 Front Door Repair - Workshop Manuals
https://workshop-manuals.com/volkswagen/golf-mk1/images/golf-mk1-226.png
Hi yes sorry i'm new to this. Its a 83 Tin top 5 door GL Model. Its the front glass manual mechanism. I have removed the door card and found the glass had come out of the slider. I have tried to fit it back in but only one side seems to snuggly fit back into the slider. It works but am not convinced how secure it is. The problem occurred when i closed the door with the window down. So i wont be doing that again. I am now going to give it a good clean and oilBriano1234 said
Always nice to know the year, and model, tin-top or Cabriolet, as well as front or rear, and manual or electric.
Dont worry.. people here to help…best they can with limited info.. most things can be fixed…
On the drive
When mine did it I removed the glass and channel (undo the two bolts) and gingerly tapped it back on with a rubber mallet.
As above if its gone missing use a fresh piece of rubber mat or foam
