Bodykit fixings
(In Topic #232720)
Some posts covering some sections of this but does anyone have any detailed drawings of the exact screw sizes for mounting the wheel arch parts of the clipper kit?
Kits online from werk34.de but doesnt specify. I have all the clips etc i think but a mixture or screw types/sizes and want to make sure i use the right ones so its a proper job.
Also the rivets, are they just for the rear arches?
Bodykit fixings
https://volkswagen.7zap.com/en/rdw/golf+cabriolet/goc/1991-44/8/853-163000/#23
Bodykit fixings
It’s hard work lol I’m doing the same but fitting to a caddy and same as you want a proper factory looking job
It is pal, nothing ever usually just plain and simple.
That drawing is a great help, thankyou very much. I can see now where speed nuts should be and rivets etc. Ill see what screws i can find that fit the plastic fitting best
Bodykit fixings
If you click the link then you will see all the part numbers. I then googled them them for the sizes (most available from VWH) then worked out what size/type screw/fixing goes where
Great link!! I can source every part number possible now. Ill crpss reference the sizes like you said. Perfect
Worth trying VW for parts - I had to buy some f the speednuts for fitting my inner arch trims and they were considerably cheaper than any others I could find.
Screws - ebay.
Screws - ebay.
Vw might be the best bet. Source them all from one place now i have all the exact numbers
