Arch liner
(In Topic #241079)
Advice/direction please. I am about to fit front arch liners to my 83 tin top. How are they attached to the arch lip and is a fitting kit available. Many thanks
Arch liners should have metal clips that go to take the screw, you can still get these from VW (well I got some a couple of years ago). They are like these but you need the proper ones as they are shorter and will line up with the hole in the liner https://www.ebay.co.uk/itm/322352260488
Arches are drilled and then it's a screw and plastic washer.
Have a look at the online ETKA for part numbers and screw sizes
https://volkswagen.7zap.com/en/rdw/golf/go/1983-7/
There are also some mount points deeper inside the liner.
Thanks for that, all makes sense now.
