85 Cabby steering boss
(In Topic #212979)
mk3 golf??
I did a search and found a lot on spline adaptors and bearing splitters but not the direct answer I was looking for.
In short all ebay ads stat fits all Mk1 variants excluding cabrio and caddy which use a mk3 golf boss?
Is this correct, I was assuming because mine was early it would be the same larger spline boss that they all have?
Is a 24mm nut so I assume its the larger spline.
I'd rather just bolt a boss straight on and not be removing anything so I can return it to standard if needed
Current rides:
