upgraded brake grief!!
(In Topic #189678)
I am going to be running an upgraded servo 9" I think it is which works just fine and also gm calipers (need to do a service kit change on 'em tho as the rubberboots are goosed!)
with 280mm discs but when I removed it all from the car to do the required service work I have noticed that the pads on both sides are not contacting the disc entirely and it's creating about a 4-5,, flange to the top of the pad
how do I stop this from happening? I was thinking a 285mm disc would sort the problem but cannot find a set of discs that size anywhere which have the correct center bore or the right stud placement….. anyone be able to help me out on this issue????
AAAAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRRGGGGGGGGGGGGGGGGG!!!
1992 clipper…….. "THE BLACK ONE"
1990 mk1 caddy…… " THE PIKEY WAGON"
1969 type 3 notchback
I have the GM calipers on 256 discs
this conversion was not originally done by myself so I'm not again 100% if the correct parts were used but when I searched for a refurb kit for the calipers and took the part number to a Vauxhall dealer he said that they were Vectra c calipers.
I need to get to the bottom of this before I go wasting my cash on a refurb kit for them as if I can't either find the correct size disc for em I might get G60 calipers…… don't really want too though as funds are really tight at the mo
abfmk1 said
Not sure I understand 100% but if you are saying the pads overhang the discs on the outside then in my experience this does happen with the Vectra caliper/g60 disc combination. Yeah a 285mm disc would help somewhat with that.
the top edge of the pad doesn't contact the disc surface….. i'll take a picky of the pad later so ya can see what I am talking about, I figured a 285mm disc would be an easy fix to the problem, just can't find a 285mm disc with the correct center bore in a 4x100 fitment
If you have a 4-5mm overhang (assuming from your first post), then a 285mm disc wont do it for you as it is will only reduce the overhang by 2.5mm
The Red Rocket! My Mk1 Tdi Build.....
My VAG family:
1982 Mk1, PD130 Tdi, 6 speed, ongoing project, to be my daily driver (one day)!
1983 Mk1, 1.8 Gti, stripped out, ongoing project, track car only.
1990 Mk1 Cabrio, 1.8 8v Turbo, G60 ECU, long term project (17 years so far)!
2008 T5 LWB, 1.9 Tdi, to be converted to camper when I've finished using it as a van!
1999 Audi A4 Avant Quattro, 2.5 Tdi, currently off the road, more work required.
2010 Tiguan R-Line, daily driver.
My VAG family:
Old dubs never die, they just get lower
dik-van-dub said
are you sure you are using the right gm calipers as they did do some for for 288 discs
ain't got a clue as they were fitted already to the car…
I fitted Cavalier GSi/Vectra on 256mm discs to my Mk1kamikaze cabby said
as far as I was aware the calipers were on the correct sides and the carriers are also GM and use shouldered bolts to attach everything seems to fit o.k. but as stated in previous post the pad wont hit the disc 100%!
I need to get to the bottom of this before I go wasting my cash on a refurb kit for them as if I can't either find the correct size disc for em I might get G60 calipers…… don't really want too though as funds are really tight at the mo![]()
There were two discs used by GM at that time.
256 x 24mm disc - Cavalier, Calibra, Astra, Vectra C
256 x 20mm disc - Corsa B 1.6, Tigra A
The thinner disc setup use slightly smaller calipers.
Vectra B discs are 288 and have to be re-drilled
Vectra C discs are 285 and have to be re-drilled
Jon`s Dad
