Most efficient swap for a mk1??
(In Topic #221816)
Regional Host NE
If your car is already fuel injected then a KR might be a simple swap, although if you are on carbs then you might be able to find a KR with a twin-carb setup that will enable you to continue using your existing fuel pump etc.
Used KR conversions complete with gearboxes and driveshafts are quite cheap nowadays if you are patient and look around.
A more modern engine would involve more substantial wiring modifications which you should keep in mind.
