POWER ASSISTED STEERING? Help thoughts and ideas please !
(In Topic #211844)
1:is this a good idea in the first place?
2: can the mk2 rack be modified to suit the car?
3: should i pick up a mk3 PAS pump and bracket for the engine?
4: should i go a completely different route?
ill do my best to keep the post up to date and get some photos on. feel free to shoot me an email or direct message, ill be very appreciative of that! (after all, seems like you lot have a brilliant idea of what your doing)
So I would ask if you are using a mk1 tranny or the 2.0L tranny
Power steering has been on the Cabriolets over here since 85 as standard.
Then would you be driving the pump off of a serp belt or standards vbelt off the crank.
3. yeah can use mk3 pas pump setup, need the alternator, pulleys and other associated brackets
4. probably
Just don't even attempt to turn the steering wheel when stationary without power steering, just try to be moving when turning, once above 20 mph you can turn the steering wheel with just a finger and thumb.
