Fuel sender unit alternative
(In Topic #209505)
Mechanic fitting new tank managed to break the original on my '91 1.8 cabriolet.
This must have happened to others and was looking for a work around
I would of thought that the Mechanic would know to insert after the tank install, and that sourcing the part would be on him..
It may be repairable, as that is steel.
Photos of the damaged item.
But still looking to see if there is an alternative or another out there
Anyone know where to get either of the above??
Pic of mine….
If it is and fits with a 1/4 twist I did think it may be modified to add the inlet/outlet pipes by drilling and brazing them in(if they are not already there….Don't know as quite new to mk1's)
Thanks very much for helping out
From the Pic, it looks like they didn't have the o-ring centered, and Lubed with petroleum jelly, a must as it keeps the o-ring in position, and allows it to slide and seal with the twist of the unit.
You one does look very similar Briano1234…wondering what the 3rd connection is for on the socket?
looking at google images they look pretty much same, only difference I can think of is the difference in tank size so the sender arm might go lower on the cab vs the tintop. might be able to swap parts between them?
Do you have a pic of it?
Is it for sale by any chance ;-)
yes for sale make me an offer
