Engine conversion help
(In Topic #202403)
for spark control you could use a mk2/corrado kr unit, with a kr or 9a dizzy:
1 - Earth to battery -ve
2 - KR ign controller plug
3 - TCI-H plug
4 - Black - KR ign controller & TCI-H ign live - terminal 15 side of coil
5 - Green - Coil trigger - terminal 1 side of coil
\- red/black - spade is for the isv control unit, the main wire is the rev counter feed
6 - Brown - Earth to cylinder head
7 - Blue/white - Temp sensor feed (use one of the 3 on the side of the head)
8 - Dizzy plug
9 - red/yellow - Fuel pump relay earth trigger
|- black/yellow - idle switch feed (12v feed with throttle shut)
\- black/white - ignition live for ECU (only on Corrado ECU loom)
