Engine conversion help
(In Topic #202403)
Hello new here, I have a mk1 caddy and I have been told you guys have all the knowledge on engine swaps, my caddy is a completely stripped down shell now it came with no engine or engine loom, it's down as a diesel on the paperwork, I'm looking to put the 2.0 abf on twin 45 dellorto carbs, but I have been looking everywere for information on what I need to start from scratch, a list of things I need and what gearbox I need from what car, engine mounts? Basically everything I need to get to have the engine in and running, thanks guys
mk1/cab/scirocco 1.5-1.8 mounts, if using an 020 rod shift box from mk1 or mk2. driveshafts mk1 90 or 100mm 1.5-1.8 matched to the flanges on the box, gear linkages 1.5-1.8 5 speed setup.
for spark control you could use a mk2/corrado kr unit, with a kr or 9a dizzy:
1 - Earth to battery -ve
2 - KR ign controller plug
3 - TCI-H plug
4 - Black - KR ign controller & TCI-H ign live - terminal 15 side of coil
5 - Green - Coil trigger - terminal 1 side of coil
\- red/black - spade is for the isv control unit, the main wire is the rev counter feed
6 - Brown - Earth to cylinder head
7 - Blue/white - Temp sensor feed (use one of the 3 on the side of the head)
8 - Dizzy plug
9 - red/yellow - Fuel pump relay earth trigger
|- black/yellow - idle switch feed (12v feed with throttle shut)
\- black/white - ignition live for ECU (only on Corrado ECU loom)
3 - TCI-H plug
8 - Dizzy plug
