Thermostatic sandwich plate
(In Topic #164986)
Website Manager
you could use a mk2 type water/oil cooler and just use a slightly larger rad. unless you plan to properly rag the car round the track this will most likely be more than enough for your needs.
alternatively if you get one without a thermostat just block the rad up with card when you're driving the car normally/in the winter then unblock it when you unleash the fury on a track
the difference on the later filter housing is easy to check, if the top bolt is offset to the side then you have a later one:
