Terrible handling ???
(In Topic #188519)
rubjonny said
whats the oddset on the wheels? I foudn ET13 wheels really affected the handling, ET35 were much better
They are ET 25 i think…
All tightened up now, so will test tommorrow.
supercharged999 said
Thought that it may be weight distribution, so was going to make the front lower, with rear slightly higher, then saw my anti roll bar was not sitting in the rubber bush… on the drivers side.
On second thoughts, going to look at AP and WEITEC shocks and spring kit….bye bye brand new coilovers…too bumpy.
I have eiback -40mm springs and std shocks on 15" steels with 195/50's. The handling is awesome
Tried a few with coilovers and it is definately not for me, but I am the wrong side of 40…
Anyone …..is it coz i have streched tyres ??? cf_emoticons__BangHead:
huw169 said
Have you had your camber and toe checked?
This would be the first check for me! Full 4 wheel alignment camber, caster and toe. Just to confirm everything is how it should be.
That is if you are sure that it is not just the oil/diesel coming to the surface of the road after all of the rain!
Do you have plenty of tread on your tyres?
Can I ask what engine you have because I find it difficult to make my 1.3 slide so I'm thinking you have something a bit more powerful.
Goly The Golf, a 1983 5dr 1.3cl having a full resto.
Got 2 l 16v ABF…tyres are new ,dunno if coilover are too hard ???
If I were in your shoes I would take it straight to a wheel & tyre shop and get the suspension checked & setup. Just make sure you set the height you want before as any adjustment afterwards will change the geometry.
Then you are working from a position of knowing the suspension is set up correctly and the rest of us will be able to advise.
