Start issue mk1 16v convertion
(In Topic #222116)
I have finally gotten far enough for the first engine start. It fires up in the first go but dies instantly after. I does that the next two key turns but then it won't start again (and die again) unless I leave for a few miniutes.
The fuel pumps turns on and I got fuel delivery to the engine, got spark also. The fuel gauge shows that I only have a few liters left in the tank but the car is leveled, can that still be an issue?
The fuel relay is new but I have ordered another one just in case the one I got is faulty.
Skickat från min MI 9 via Tapatalk
I wanted to have a look down the tank and inspect the in-tank fuel pump and there was a very small amount of fuel in the hose to the right in the picture. In My expirience there is usualy quite alot of fuel comming out when prying of the hose. Maybe its loosing fuel pressure?
Also the fuel distributor may need bleeding, I can't remember if there is a special procedure for this or its just a case of getting it running (maybe on fuel from somewhere else) and waiting for them to clear of air.
I created a short wiring loom which consisted of a plug-on connection to the 5th injector and a momentary switch, so I can fire the injector on command and it was helpful to diagnose a number of issues such as these. It saves needing to squirt a can of easy-start or petrol spray down the airbox otherwise.
The other piping seems to match the part drawing in the link.
https://volkswagen.7zap.com/en/rdw/golf+cabriolet/goc/1987-44/2/201-69020/
I have ordered a new Bosch fuel pump and I hope that a new fuel pump will solve my problem. I have a feeling that the injectors won't open due to low fuel pressure.
It would also be worth measuring the fuel pressure for a proper diagnosis before replacing parts, but obviously I appreciate a fuel pressure test gauge or a garage visit is about the same price as a pump anyway…
Next problem is the oil varning light blinks in the instrument cluster. There seems to be circulation since I had to refill with more oil after the first start due to filling the oil filter and so on after engine renovation. The oil pump is also new.
Are the sensors incorrectly wired? I just figurer that blue wire goes to blue sensor.. anything else that I can check?
