Sorted :)
(In Topic #177394)
have the diagnostics been wired in, if so check them
Follow rubjonny's advice
a quick way to bypass a faulty ign switch/wire for testing is run a wire from battery + to the coil +, if car startup fine then you know the problem is with the ignition feed somewhere
there may not be an ecu relay it depends how the loom was made, i cant see a fuel pump relay either…
It's the first time I've looked at the fuse box since I've had the engine conversion done by a garage last summer. I noticed there wasn't a fuel relay too. Not sure of the implications of this because it ran fine before this hiccup.
I think it's a bit beyond my amateur guesses now so will have to take it in somewhere.
There was me hoping it would be a simple relay.
if the immobiliser kicks in the car can still start for a few seconds so that isnt what is stopping the spark
or it may be the ecu immobiliser was defeated, if so then i think it is normal for a fault to be shown even if the car starts ok
so basically get it sparking first then see where that leaves you
