Rear brake drums to disc conversion
(In Topic #222646)
I will go through this conversion om my -87 cabriolet (1.8l) this winter and I have bought Golf mk2 calipers and carriers. I do need a bit more bits and pieces to make this happen.
I have found this shopping list:
New Scirocco 16v Parking brake cables (one for each side).
Stainless, or stock 16v rear brake lines.
brake fluid for your system.
New or used calipers, if you get used, make sure the parking brake section is not frozen.
Caliper carrier brackets.
New or used stub axles for parking brakes.
bolts for stub axle, caliper.
brake pads (new).
brake discs (new).
brake dust shield (optional, really).
Disc wheel bearings.
New grease seals - don't reuse the old ones
wheel bearing grease.
new grease caps for the bearing (might come with a bearing kit depending on where you buy).
16v Scirocco Brake pressure reducers (inline at the master cylinder).
Adjustable Proportioning Valves.
Most of the parts are no problem to find, the only exeption is adjustable proportioning valves. Where can I buy these valves now a days? Where should these be mounted? Do I need brake pressure reducers (mounted in the master brake cylinder).
Some go with mk4 brake calipers instead of the mk2 due to siezing handbrake if I understand correcly.. Will that be a problem om a purely sommer driven car?
I didn't use any proportioning valves for the rear, but I did upgrade the fronts at the same time. I don't know if this made any difference.
Later cabriolets had proportioning valves at the master cylinder. They can be used. They are quite expensive new however. They mount into the master cylinder.
They aren't adjustable as far as I'm aware but are there to stop the back locking up.
The mk4 calipers are aluminium instead of cast so they don't corrode. If you are completely stripping and re-building the calipers then they should be fine. However mk4 calipers are about £80 each new. Is it worth the hassle of buying and installing the re-build kits to then have them seize later? I've had mk2 that's seized, and used mk4's that seized. In the end I went with new as I was fed up with doing them.
Having a car only used in the summer is sometimes the issue as stuff is left for months to bind.
If you go with flexi lines to the calipers (which you don't need to do as solid lines can be used, then you will need to make a bracket attached to the beam to make the transition.
Routing of the handbrake cables is interesting. Don't cut the tubes mounted to the body and run the handbrake cables through the beam.
Ian
Wilwood simple models (one for each line):
Wilwood Disc Brakes - Porportioning Valves & Pressure Valves
I really dont need to adjust them myself if I can find other ones that I know will work. I have found Golf mk2, new for a reasonable price but have to find a "How To" to install them.
I have also upgraded front calipers (mk2 GTI) and master cylinder (22mm).
Last edit: by Vidde
and I am a tad under the weather to go take a look…
The pn is 533612151
Is where they are on my LHD Cabriolet….
The Wilwood works well, have it on my mk1 rocco, Polo 6n servo moved over, 25mm master, wilwood calipers up front with 256 discs, polo gti rear hubs, calipers and discs back end, bias at around 50%, no load valve or reducers, brakes are awesome, no locking upVidde said
Thanks for your reply! I do not have any proportioning valves on my cabriolet since its a -87. I have to source new ones.
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
Hi - I've been looking at the Wilwood Combination Proportioning valve - your set up looks great. Have you any more photos? Im installing a mk2 gti MC and 9" servo, just keen to see how I can make it all fit. Also, where did you get the fitting to split the rear brake lines?
