Really stiff 02a cable clutch
(In Topic #187166)
Just getting to the finishing stages of my ABF conversion and the clutch is giving me a headache.
I elected to switch to 02a box as one came with the engine. I have swapped the shifter tower and change mech to an 02j type from an Audi A3 - that part works a treat. I can select all gears using the shifter with the engine off without pressing the clutch, so my shift setup works.
However, when I start the engine I have to put huge pressure on the pedal to be able to engage the gear that my steering column is moving quite a bit and it's really difficult. Probably too stiff to drive for any length of time and i'm used to the mk1 std clutch..
My cable is a Mk1 1.3 and I have repaired the bulk head with a plate bolted in place. The cable runs along back of inlet manifold over brake servo and down behind header tank to the clutch actuator from the rear.
I am going to have another look with fresh eyes this afternoon, but thought I'd see if anyone else has had similar issues.
Many thanks
Huw
i just about got gears with the 1.3 cable but the clutch was slipping, i shortened the outer sheath on the actuator end of the cable by 2-3cm to give me more adjustment,(use a grinder to cut the metal inner rings) the cable wasnt so taught after that either
Stumped! Might just get new clutch kit as its all off.
I still don't get how it wasn't actuating though. I'm not convinced there is anything wrong with the clutch parts. Everything seems to work fine off the car. Clutch lever, cable, release bearing & bracket, etc. Even though the pressure plate needs ~100kg load to operate it, this should be well within the capability of the cable mechanism with the mechanical advantage available. With the amount of force I had to put through the foot pedal I'm suprised something didn't bend or break. As i type, I'm wondering if my release bearing was binding on the centre shaft. I'll look for evidence tonight.
Confession time - I bought a Transmech kit
Sachs are good, but still quite pricey even when discounted. I know Transmech don't get good press, but I thought I'd give one a go to see if it solves my problem (in the short term…
Have you tested the cable off the car? Is it sticky? Is it sticky if you bend it tight? Have you simply used the original cable? I use a caddy diesel cable as its metal reinforced where it exits the bulhead - works a treat (top tip - fill the cable with oil before fitting)huw169 said
Hi All
Many thanks
Huw
See here for a piccie http://www.paul-cullen.co.uk/Images/Golf/DSCF2279%20%28Small%29.JPG
Jon`s Dad
New clutch arrived today, and in comparison the old clutch is 'not so fresh looking'.
However, that still doesn't explain the stiffness. New clutch plate takes same load to actuate as old one - my weight. New clutch fitted and pedal is nice and easy. I can only assume the release bearing was binding or catching on the spring legs, but there is no visible damage. based on the forces involved, I would expect to see evidence.
Strange one.
And a major pain doing the box on your own….
Oh, Transmech clutches don't look bad at all. Time will tell though. The friction plate actually had LUK stamped on it..
When I fitted the box and cable only, the clutch was fine.
After I had fitted all the other bits (drive shafts, gear change cables, starter, etc) it was really stiff/not working agin.
Massive head in hands and shouty moment. Was just about to start stripping it out again as I couldn't see how adding the other bits could influence the operation of the clutch.
Then got logical and started undoing things a bit and trying the clutch and found the problem…..
I released the front bolt that holds the changer bracket to the top of the gearbox, and the clutch worked perfectly. I must have swapped these bolts for longer ones, and the front hole is through the gearbox casing and the longer bolt was stopping the actuator mechanism resulting in a really stiff clutch that doesn't release the friction plate…
I suspect I now have a cable that is a few cm's longer than it should be so i'll be carrying a spare, and my bulk head plate still looks fine. Clutch is now really light and works well.
I was not a happy chap for a few minutes though when I had the problem back……
Just in case mt Transmech turns to chewing gum…. LOL
