radiator Hose outlets and inlets
(In Topic #197622)
The coolant gauge on the dash goes just past half way and there's no power to the radiator fan connector?
The radiator it's getting hot but only on the side with the hoses.
The hose on the side of the engine, going into the top of the radiator Is hot, but the hose below, going into the thermostat is cold/cool still.
Does mean the thermostat is knackered? Or I've got a duff radiator?
Could be a simple as an air lock in the coolant system?
http://www.clubgti.com/showthread.php?267196
for the oil pressure you bin the mk4 switch, take out the allen head blank from the spare hole then fit both mk1/2 pressure switches.
