R1 carbs keeping sliding of !
(In Topic #191809)
Thanks al
Is it a home made manifold?
How long are your silicone joiners? Loner they are more flex on the carbs putting more strain on the clamps.
And my manifold got these extra ,dont know how to say it right bench at the end.
Maybe you have created a stud from the carbs to a solid place on your engine so the weight on your connection would better…….. so said if i don't know the right words for it sorry…
Brad. said
Are your pipes swaged?
No they are not. The manifold end is fine, it's the carb end that's the problem. It's a home made manifold by the previous owner and doesn't totally line up with the carbs like the one in the pic above.
The silicone joiners are about 1.5 inches long so I could make them shorter
Style said
Strange i don't have this problem but i used the original mounting tubes from the R1.
Thanks for the pictures.
ive seeen folk use a little bracket to secure th carb upright.
the manifold not lining up could also be the issue though, that will creat stress on one or two silicones.
