Mk2 calipers 12mm or 20mm?
(In Topic #215886)
I'm putting in mk2 239/20mm rotors and calipers in a mk1 '76. I see VW Heritage sells mk2 calipers which they claim work with either 12mm or 20mm rotors, however their part number only pairs with 12mm rotors on various part stores. According to ETKA there are two different types of calipers for the MK2, fitting 12mm or 20mm rotors. I'm abit confused by this, so wondering if anyone could confirm the correct part nr for the calipers with 20mm rotors?
Also, do the bolts and rubber hoses have to match the calipers or can I buy new MK1 spec? Thanks
Early 77 year model Golf. 4-Door
I don't know what new ones are worth, but they would be cheaper at a breakers with a quick hone, rebuild kit, and bleeder valve…..
VWII is all that came on later MK1 Golf 1.5-1.8, but MK2 had VWI on the 1.3 which only take 10mm discs
VWII have 'VWII'v cast into the outside, VWI are plain
Still abit confusing why ETKA shows two types of calipers for either 12 or 20 mm rotors though. 1H0615124A and 1H0615123A are the ones VWheritage sells, but 1H0615123C and 1H0615124C apparently pairs with 20 mm rotors on various part stores..
goldie_88 said
Perfect man, just the reassurance I needed.. sucks have wrong parts at hand..
or Having the right part number on the box, and the wrong part is inside as a Surprize…… after waiting for it to arrive for 2 weeks…..
