Lower brace
(In Topic #224030)
If your lower control arms are straight, and you don't have a castor difference then I would say the lower bar assembly is ca-ca. Can you possibly have it upside down, and are the end plates at 90 degrees.
Do you need to have the web with the 2nd bolt hole above the chassis similar to the K-bar setup in the link
MK1 4-Point Lower Stress Bar VW MK1 4-Point Lower Stress Bar [SUSPLBAR1/430300] - $250.00 : USRT | Usually Sideways Rally Team | Hardcore VW/Audi Performance
Re:
Unsure about the 1 you mentioned, mine was a pretty basic bar with some plates , your 1 looks more "fitted"Early-1800 said
The one fitted by VW to some Cabrios and Scirrocos was a K-bar design. However the logic is the same, bracing across the chassis legs by a device fixed in 4 places, two on each side. The plates on yours need to be above the chassic leg not below as you have it in your pics?
