View topic: KR wiring – The Mk1 Golf Owners Club
KR wiring
Need bit of help have couple plugs left for the fuse box, the red wire is red/black,  any help will be good thanks  image.jpeg image.jpeg image.jpeg image.jpeg
1. black wire? if so probably the ignition live feed to power the isv control unit. pop this to G spade on fusebox 2 or 5
2. outside and oil temp senders for mfa cluster
3. all looks well here?
4. check fusebox and big white connectors to see where the wire has been pulled out of. chances are its rev counter for fusebox or isv box
Thanks will look at them
Need more help again I have started the project again after rough year and half and need bit wiring help and where do the metering head injector lines go too. IMG_1233.JPG IMG_1234.JPG IMG_1235.JPG IMG_1236.JPG IMG_1237.JPG
1. doesn't matter what order the lines go, just fiddle till you get them sat neat as you can. its tricky to be sure :lol:
2. yellow/red dash temp sensor, green/red isv controller temp. these go to the 3 black sensors on the side of the head. the 3rd sensor is for the ecu which has a blue/white wire.
3. not sure what I'm looking at here?
4. all the black wires go to the positive side of the coil, its the side with 3 spades visible at the bottom
5. cold throttle enrichment valve, this is the 2 pin metal thing on the back of the airbox with a vacuum line to it
Thank so for the reply going to do them tomorrow night now
