g60 mk1 engine wiring
(In Topic #182491)
Any ideas as to what i should be testing/looking at?
Its an 83 mk1 with a g60 engine installed
thanks
next run a power pin to E/14, with 2 wires. one feeds the fuel pump, the other crimp a male spade on it and then crimp a female spade to the fuel injector and lambda probe wires and plug it in there.
rubjonny said
for an original conversion you would need to run the yellow/blue fuel pump trigger wire from ecu pin 3 to D/13 (used to go to g1/3 on the ce2 loom), then fit a 67, 80 or 167 fuel pump relay to slot 2.
yup looks like i missed out the fuel pump trigger wire, will have a go in a bit
my fuel pump relay has this number on it 3.300.210
is this the correct one?
i remember changing it when i had a carb conversion as the trigger was on the opposite corner a while ago
thanks
so if it doesnt work i run a wire from the negative on the coil to the rev counter pin on one of the blocks?
so far i have
green to negative side of coil
red/yellow and red/white spliced into e14
black/yell to b8
all earths connected together going to the chassis
blue/yell to d13
the fuel pump does not prime on ignition but pumps when cranking then stops when not cranking after engine fires the isv doesnt hum on ignition
i saw this in the guide
Now for the Ecu power wire this the large Black with yellow stripe and needs to be connected to a switched +12v I used a multimeter and used one of the spare terminals on the fusebox make sure it still receives +12v while cranking or it wont start. - this is the wire i have connected to b8?
Last edit: by G60RGE
for the ecu relay you could splice to the coil live, but I prefer to add an ecu relay above the fusebox for it
spliced it into d23, when i heard the isv buz on ignition i knew it would be problem solved!!
started right up im well happy
thanks for your help mate
no pulse to the injector and no spark
is the blue with yellow actually needed in this swap if i'm still using the mk1 fuel pump relay? it looks like trigger OUT from the ECU but i it looks like the mk1 just using ignition as the trigger.
red/green is to ignition. red/black on black plug next to starter # 50. (did try #50 too)
red/white (O2) & red/yellow) fuel rail - to fuel pump relay #87
black/yellow (ECU and ISV) - to fuel pump relay #15
brown/white - ground to head
brown (2) - ground to battery
my fuse box version is page 9.
http://chris.chemidl.in/wp-content/uploads/2015/04/Vw-wiring-diagrams-1982-1983-1984.pdf
the started turns the engine just fine.
I don't think the fuel pump is powering on from #87 so i took the cover of the relay and closed the circuit with my fingers and i hear the pump run, tried cranking like this, still nothing. relay is getting battery and ignition power. fine.
one note, with ignition on the can feel with my hand that the ISV has is humming a little. so the black/yellow does have powe with ignition on and the ground is making its way into and back out of the ECU.
been stuck for a few weeks on this. help me out dub fam. :-)
