G60 brakes mk1 - Epytec adapters
(In Topic #223324)
I'm doing a G60 brake conversion om my cabrio. I'm using the original hubs with Epytec brake adapters.
My problem is that the carrier om the left side is hitting the disc.
Did anyone else expirience this problem? I did not get any fitting instructions when I ordered the brake adapters and I have emailed Epytec about that but they seem reluctant to send me them now..
Is the disc touching on the side? The shim should adjust that.
Rich
The discs are the correct ones? I had 1-2mm clearance on either side.
280 carrier is 25.5mm
256 carrier is 24mm
280mm disc is 22mm
