extended top mounts, do they make much difference?
(In Topic #189416)
Thinking about getting extended front mounts to help with the ride quaility. I understand it will depend on the suspension used, but the set up have at the moment is very hard and was wondering how much difference people have experienced when using the extended top mounts? The idea of having more travel to play with will hopefully reduce harshness but interested in peoples actual experience.
Many thanks
Dan
the ride quality depends on your dampers as well as the ride height, what kit have you got on there?
The top mounts just give an extra 1" shock travel, the wishbones still raise upward with lowering?
Op, I've raised my actual turrets in my car by 45mm, in essence should give me 45mm more travel on the coilover. Gives a bit of compromise to the lowering lark, or, if your bottoming out/all the way down on your coilovers you'll see 1" more drop
Thanks.
paceman said
shepp Appreciate this a very old post - but did you go with the raised mounts and did they make any difference?
Thanks.
They make the world of difference when using crashy coilovers.
Belix said
Is this something one can buy (and if so, where?) or do you need to fabricate them?
Mk1 Golf / Jetta / Caddy – Raised Strut Tops | coltechclassics.com
