Abf wiring
(In Topic #202249)
http://www.clubgti.com/showthread.php?219775
Abf wiring
yellow spade is oil pressure switch
red/white spade is fuel live, originally for WUR but for the abf loom it may have been used for lambda and/or injectors?
brown/white spade is earth to head for the MK1 MFA cluster, if yours is non-mfa you dont need it.
this thread may also help you out a bit:
http://www.clubgti.com/showthread.php?249714
brown and white I've removed as no mfa and yellow I will have to remember connect
you should have a thick-ish red wire from the round plug on the engien, thats injector live and should go to the large spade N
Abf wiring
you only need 4 wires for an abf install, the last 2 are spares that used to go to the distributor:
1 - coil negative
2 - battery negative (tie this and the ecu earth together and run to battery)
4 - coil positive
6 - abf ecu pin 8 (red/green that used to go to mk3 coil)
