ABF Weber ignition questions!
(In Topic #191340)
Jack
Last edit: by j4cko56
The Kr and abf dizzy are different, abf is set and electronically advances.
Jack
1 - Earth to battery -ve
2 - KR ign controller plug
3 - TCI-H plug
4 - Black - KR ign controller & TCI-H ign live - terminal 15 side of coil
5 - Green - Coil trigger - terminal 1 side of coil
6 - Brown - Earth to cylinder head
7 - Blue/white - Temp sensor feed (use one of the 3 on the side of the head)
8 - Dizzy plug
9 - red/yellow - Fuel pump relay earth trigger
\- black/yellow - idle switch feed (12v feed with throttle shut)
I complicated it when I used megajolt, but that was so I could map my ignition to suit mods.
