ABF throtle question
(In Topic #190388)
It happens about the point where the butterfly closes when slowing down in gear. Most of the time I take my foot off the accel. pedal and move to the brake the car slows smoothly. However, every now and again it slows up rapidly on the engine. I would imagine VW intended it to slow smoothly, but what controls this? Is it the switch on the throttle body? I broke it off the bracket and had to bond it back on, maybe I have moved it a little? Seems strange it only happens now and again.
(I only notice it now I'm not giving it 'beans' all the time…)
Any suggestions?
this link has the abf label files for vagcom and further down also explains how to check idle switch:
http://www.clubgti.com/showthread.php?199583
in there somewhere is a link to set the throttle stop too I think, but if not the pdf is in my sig plus another on doing the basic settings for throttle and isv
No fault codes. TB clean, but will pull it off and check.
Thanks for label files, but not sure I really know what I'm doing with VCDS.
Any chance of posting up the idle/TB switch setting pdf as I can't link to your signature docs. Google blocked…
Many thanks
plus its handy if you get an android phone as you can use it to sign onto the device then it'll backup all your settings and contacts for you (if you want that kind of thing)
rubjonny said
i would go with a gmail account if you're worried about google tracking all the porn you are searching for
Your not wrong….
I do have a google account, but it just doesn't work at the mo. Will keep trying
