ABF conversion & heating.
(In Topic #191770)
I just matched up the connection pipes through to the heater matrix top to top, etc. Was this wrong? Should I have swapped them around?
Huw
Seems to be fully closed. If the bonnet is not sealing against the scuttle seal, would that cause this?
rubjonny said
i doubt it no, feel the hose after your valve it should stay cold when the valve is closed. if it still gets hot then valve needs replacing
Common fault on the Mk1/Citi Golfs, worn heater valve that needs replacing.
1983 Golf GT 2.1 16V with throttles/1978 Golf LS 2.1 ABF with throttles/2008 Citi Storm 1.4i/2007 Hyundai Getz - my daily
Although with these temps getting so low, no real hurry at the mo….
As per rubjohnny, common fault. If only I could get my fan working on speed 1, I'd be a happy chap.
