ABF conversion & heating.
(In Topic #191770)
My heating is always on even when I have the lever all the way to the cold side. It was not like this with the old 1.8 DX.
I just matched up the connection pipes through to the heater matrix top to top, etc. Was this wrong? Should I have swapped them around?
Huw
Huw
makes no odds which way round the hoses are, its your heater valve thats causing the issue make sure its closing fully
Cheers rub
Seems to be fully closed. If the bonnet is not sealing against the scuttle seal, would that cause this?
i doubt it no, feel the hose after your valve it should stay cold when the valve is closed. if it still gets hot then valve needs replacing
Common fault on the Mk1/Citi Golfs, worn heater valve that needs replacing.
1983 Golf GT 2.1 16V with throttles/1978 Golf LS 2.1 ABF with throttles/2008 Citi Storm 1.4i/2007 Hyundai Getz - my daily
Nice one guys, i'll check it out.
Although with these temps getting so low, no real hurry at the mo….
You'll feel it come summer again. I replaced mine with a cheap eBay variant that leaked, changed it for the genuine article, more expensive but works a treat.
As per rubjohnny, common fault. If only I could get my fan working on speed 1, I'd be a happy chap.
