9a metering head.. doesn't fit.. solution help required!
(In Topic #190958)
So I have a 2.0 9a engine in my car now, and I placed the air box with metering head and it's wayyyy to high, can I just cut the bottom out to fit or is there a proper solution to this?
Also, what heater pipes do I need to connect to existing me pipes out of the heater? ones that came off the corrado are too big?
any help appreciated !
cheers!
for the matrix pipes you need mk1 1.5-1.8 ones and dont forget the heater valve
Are the mk1 golf pipes stepped down then as my engine has a larger I.D then the heater valve inlet?
View topic: Project 83 MK1 cabby, several years in the making! - The Mk1 Golf Owners Club
oh and while I'm on the subject of heater matrix, I used a MK3 Golf automatic T piece in the hose from the side of the engine and an early mk2 KR metal pipe (early metal pipe has extra outlet that later kr and 9a dont have) to provide the heater valve bypass required on a mk1 golf.
If you can find an early kr side flange then you can run the outlet from that to the metal pipe, or you may find a mk1 side flange may fit? if you cant find an early metal pipe 2x T pieces would do it 1 in the side hose and 1 in the hose to the metal pipe
