2l 16v ABF conversion Radiator choice...
(In Topic #187401)
Got a mk1 with ABF conversion, but it has the 1300 Driver radiator in it 46cm long x3.5cm thick x32cm height (topfill radiator )…..fine on the motorway, but the guage moves too high in traffic.
What are the options, as RADTEC want £350 for a custom radiator.
Last edit: by supercharged999
LOL. I think you have your units mixed up. cm's?
I have a std GTI one in mine, but it's not finished yet so haven't tested it on the road. Would be interested in the thoughts of those that have done this conversion also.
huw169 said
No wonder that gets hot, that radiator is TINY……
HA HA…YEP changed it from mm to cm…
My New Year's resolutions are: 1. Stop making lists. B. Be more consistent. 7. Learn to count.
But it wud be nice to not have to keep checking the gauge once still in traffic :/
If u want a top fil then i have read somewhere that u can modify a 16v rad into a top fill urself if ur quite handy with a tool kit
Yep - that's what I did
A bigger rad is one option, but the space is really tight. I might just get a new rad as mine is probable sludged and less efficient.
I'm wondering if a lower temp thermostate would help.
I'm also planning on getting a switch to read the oil temp as I have the gauge, but it's not wired in.
Thermostat will not help. However, I have an 87deg one fitted from an 8v, and the 16v one is 82deg opening. I will change it for the 8sdeg one, but all this does is open the coolant flow to the radiator a few degree earlier. Some people drill little holes in thermostat to keep some flow when closed, but all this does is slow the warm up process - not a good idea.
I'll buy a new rad as mine is quite old. Bigger rads are more custom applications, and I'm not paying £200+ for a few degrees cooler. Std 1.8Gti rad is about £30 and should be more than adequate.
New rad switch. Can get ones that kick the fan in at 95deg and switch it off at 87deg (might ebven be the standard spec, but hard to tell). If you want, you could put a manual switch on the dash to switch the fan on when you want, but this is not really necessary. I wouldn't remove the wiring for the fan switch though.
I left mine idling yesterday for ages in the garage. Needle didn't get past the LED and the fan kicked in a few times. When I'm out on the road though it does get hotter, which I was surprised at as there is more cooling air flowing through the rad.
Need to get my oil pressure and oil temp gauge rigged up.
Used a non contact thermometer on the body of the water temp switch, rad, oil temp switch, and bottom rad hose just to see if thermostat was working. Rad showed 100deg on top surface as fan kicked in, but less on the rad body. Water and oil switched about 90deg which is about the right running temp for the engine, so should be good.
I also have an original manual and it states that anything between the upper and lower areas on the gauge is fine. I have a of 100 miles to do tonight from Portsmouth to Swindon, so we'll see how the temperature settles as I don't think i'll be able to resist a bit of right foot…..
also if as you say rad is old it could just be a bit furred up inside. my mk2 abf with nice new 1.8 8v hella rad runs below 1/2 but thats more to do with the abf cooler thermostat than anything.
no need to mess with lower temp radiator sensor, the stock one is fine
I'm not going to touch my fan switch either as it seems to be functioning fine.
New thermostat at 82degC will be going in.
Need to get one of those dual oil pressure switches for my gauge. Who sells them? GSF?
http://www.ebay.co.uk/itm/Oil-Pressure-0-10-bar-M10x1-Sender-Unit-replaces-VDO-unit-Two-Post-/371042081669
http://www.ebay.co.uk/itm/Oil-Pressure-0-5-bar-M10x1-Sender-Unit-replaces-VDO-unit-Two-Post-/390657708382
I'll get one on order.
With my coolant header topped up to the right level
if its reading 170 on the mfa the wire is either shorted to ground somewhere or the sensor is dead
I want to put the slim fans onto the rad, but a little confused over choice. Slim fans range from c£20 to £300!
Anybody know which ones to avoid or buy?
What are the three wires on the fan for?
As above, mine was running to the right of the led.
Last edit: by Craigt
I've been searching the interweb tonight and I reckon that the fan is two speed, but I'm thinking of having a push fan on stage 1, and pull fan on stage 2… but then again I'm also seeking a standard GTI radiator cowling to fit over the rad.
