280mm discs
(In Topic #222974)
Disc dimensions
I'm running a 280mm conversation on my tintop. The conversation was done before I bought it.
I bought a new set of discs from VW heritage part number WC615KBD404C. But after taking off the old ones and comparing them the depth dimensions are different so the new disc sits too far out from the hub if you can picture it. So the outside pad would need to be paper thin. I'll post a couple of pictures. Does anyone know where I can buy a new set with the same dimensions as the old ones?
As you can see from the pictures there's 10mm difference in depth. Old ones 45mm and new ones 35mm
Nat
Example picture below
Regional Host NE
not the height Brake Disc Type Externally Vented, Outer diameter 280 mm, Brake Disc Thickness 21,9 mm, Height 39,2 mm, Hole Pitch / Number 04/05, without wheel hub, without wheel studs
Regional Host NE
Nat
