20vt loom questions
(In Topic #212518)
Would this be specific to a certain engine code or would it work with any 1.8t??
short answer is usually if you keep the same type of throttle body then looms are compatible, but not always.
precat lambda: narrow or wideband
some need ECU power to pin 121 some dont
EGT: some have some dont
VVT: some have some dont
throttle pedal wiring, early actuator differs slightly to late pedal
if the loom was made how i advise the main loom will plug ionto a connector on the passenger side and can be swapped, which solves some issues.
But the EGT, throttle and lambda are on the big plug which will be in the main engine harness. not toooo bad couple pins swapped and added job done. For the small pins the empty slots have spare pins in and they're easy enough to crimp the wire to, and for the larger terminals those are standard/power timer so wi8dely available and cheap.
ended up buying it, so we'll see what any issues are, further down the line when i come to fit it!
