20vt engine code BAM conversion. do I need these?
(In Topic #219146)
I have a 20vt engine code BAM and my car is a late clipper.
When i bought the engine i was also give these but I'm unsure of what they are and what they do and if they're needed. could someone shed some light on it please.
thanks
The second one is as well but I haven't a clue as to what it is off of but not a MK1.
Don't have a clue as to the 3rd, unless it is for a oil cooler on the transmission.
I'll wait to see what the last thing is then give them away. thanks
3rd picture I have no idea?
This site may help if you have any part numbers on the pipes or you be able to spot them in the pictures?
https://volkswagen.7zap.com/en/rdw/
The r12 based systems used mineral oil (clear or brownish after a good run)
The R134A uses PAG oils of different viscosities depending on the manufacturer of the compressor as the other components don't care. Which is why depending on the year, we have o-rings or Nitrile 0-rings and different composites of rubber being used as the different gases can escape because the o-rings/rubber are designed originally for the type of Gas refrigerant being used.
So it isn't unusual for components to Drip residual oil.
I've deleted the aircon so I can finally get rid of that stuff I've been kicking around my garage.
