2.0 20v na
(In Topic #186557)
engine into mk1
any help would be great, cheers
main problem would be the exhaust manifold, the mk1 20v stuff is for turbo so wont go on n/a block you'll probably have to make something up custom
iv also been looking into the possibility of a 02s 6 speed box do you think it would go well with it?
i did think i would have to have a manifold made, and will prob be most expensive part, id like it to be a 4 branch type, iv got a kr in at the min with a 4 branch and will see if it can be used with relivent mods. just waiting for the right engine to turn up now.
a kr 4 branch will be close I recon, just a case of lop flange off and make something suitable up i guess.
not sure if you can get a transverse 20v manifold, if you can then maybe fit that and make a downpipe from half 20v and half mk1? shouldn't be too bad that way, as i think mk4 manifolds end up closer to driver side than on mk2 manifolds, plus you wont have to work around the 020 rod linkage
