16v engine conversion wont idle at normal speed ??
(In Topic #198206)
any ideas guys ?
Thanks jamie
rubjonny said
what mangement are you running, 9a or kr?
Hi I think its kr as the 9a isv I tried had a different wiring plug …How could I tell ? ….iv also brought a kr isv and its the same idles at 1400rpm …found the part number for the one I have 035133455F and brought one of them used but its worse than the one I had so got to send that back too :/ don't know it a new one of these would solve it though ….iv got it down to 1200rpm idle with the old one but any slower and it will stall when revved
THanks for the help
jamie
Last edit: by mk1 Jamie
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
if its 9a then it'll look similar but there wont be a WUR and you'll have a 2 pin white temp sensor in the head plus 1 black rather than 3 black ones and a big brown thermoswitch
I do have a wur and I have 2 sensors a blue and white wire going to one and a green and red and another wire going to the other …I did try swapping these around as Id read they are the same sensors and it did run different slightly better maybe does that mean a sensors no good ?
It is booked in for an MOT and they are going to check the timing and co for me so hopefully they will beable to sort it if I cant
Thanks Jamie
swap the red/yellow wire between all 3 sensors and check what the dash temp says, if one is miles off what it should be then this sensor is duff
Thanks for all the help
Jamie
