02j mk1 conversion to enable cable operated clutch. Help please
(In Topic #192239)
I'm trying to locate a list of parts to run a 5 speed 02j gearbox on a cable operated clutch for a mk1 20vturbo conversion
Can anyone point me in the right direction of what ex act parts are used? As I'm confused with people swapping shifter towers clutch actuators etc!?
Any list of part numbers? And what's the best type of gearbox to run with regards to ratios? As I want a quick acceleration but a good 5th to cruise in that won't eat fuel on a long run.
Thanks In advance!
MK1 golf 3door GTi alpine white ABF conversion
Strip down and rebuild process
View topic: A65 GLD strip clean and rebuild - The Mk1 Golf Owners Club
all parts available from SEAT except the cable bracket, but you dont want the one in the link anyway you want the toledo version of it part number 357 721 352.
only trouble is with 02j tower the reverse switch hits the cable bracket, you could modify it or make your own bracket even as theres not much to it really, other solutions involve machining down a blank to fit in the hole, or swap a mk1/2 spade type switch with spades bent a bit to clear
Will have to wait and see
