topping up gearbox oil? GF 1.3
(In Topic #169555)
I'm really not sure where to check level or where to top up, can you give any advice please?
Ideally I would like to change it.
-z
i pressed the little red button
I cant remember if it was M10 or M12 I got but they will let you have a look at the shop and buy the ones that a 17mm spanner fits on,
Then tap this into the bung and undo with a 17mm spanner! They can be tight but once you crack them off its easy peasy
I hope this helps?
Goly The Golf, a 1983 5dr 1.3cl having a full resto.
so i fill it right up until it comes out the top?
oh can you recommend which oil to get and how much does it take?
-z
Last edit: by zorg
As for the oil I'm not 100% sure but again Mr Haynes has the answer, he says SAE 80 or 80W/90 hypoid gear oil.
Britney.
I know the oil in mine will not have been changed, its bound to be waaaaay past its best.
Z
