Thermostat housing/ Coolant flange
(In Topic #154073)
nearly got the old girl doing, other than an intermittent starting issue which I may have solved, my thermostat housing is leaking where it joins to the coolant flange for the top water hose. It only drips when under pressure so its not a blatant hole, just an issue with the seal on the join.
The thermostat came with 2 paper seals, none of which fit, currently all I have on it is the O ring behind the thermostat, then a bit of blue sealant on the join, and its leaking quite bad. I know these flanges are obsolete, but luckily there doesn't seem to be much up with it! I have found a gasket on VW heritage which looks like the one for the job, anyone shed any light on this or tell me what I need to do to stop it leaking?
http://www.vwheritage.com/vw_spares_Gasket-for-water-pipe-most-models-exc-GTI-G60-Rall-052121091A_act_shop.product_pID_48049354_lang_EN_country_GB.htm
Cheers!
