Starter motor
(In Topic #224866)
The bolts go through the starter and through the casing onto the front engine mount.
Before I undo both do I need to support the engine or will the 3 other mounts hold it all in place ok
Its not a "real" engine mount as such, its a torque reaction thing, which means it supports the engine when its running and the power goes on and off etc, but doesn't carry any weight. So its completely safe to unbolt and remove to replace the starter motor.
If its an auto……..its behind the engine (under the exhaust manifold), best of luck changing it unless you have a 2-post lift.
If its a small block……I have no idea where the starter is.
Starter motor
I presumed big block was 1.8 up
However the one and only one I have removed, for a clutch change on a '81 1100, had a support bracket at the opposite end to the bellhousing covered in oil and gunge that we couldn't see and spent ages trying to withdraw it after we'd removed the couple of obvs bolts that held it on…..
wilko13 said
Cheers for that sorry I see a 1.6 carb as small block lol
1.5, 1.6, 1.8 are big block
1.1 and 1.3 are small block
Starter motor
The secret is…
Remove the right side wheel to give you light.
Remove the 2 rear shield mounts 10mm bolts, then replace the lower one on the starter and just start the bolts it is a y shaped bracket that bolts to the block once you have remove it to get the other bracket free and to get the battery cables off, reattach it to the block, and to the posts.
Remove the Battery feed, and the solenoid wire.
Remove the 3 13mm, the second one on the heat shield you have to use a short socket and a wobble extension.
Last thing you remove is the lower bracket as it is supporting the weight of the thing. Once you have it out usually towards the axle and down… Going back place it up there and use the lower bracket to support it, way easier….
Granted I usually tape the upper bolt to my socket so it can't fall out, along with about 2 feet of extensions and my short stubby ratchet.
