Stalling Problem
(In Topic #72579)
Stalling Problem
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
Is it OK when its fully warm, say after 10mins or 5+ miles? If so make sure the preheat pipe is connected between the tinplate on the exhaust manifold and the air filter inlet pipe. If it is stick your hand under the rear of the air filter and check that the two small rubber pipes are connected to the underneath of the air filter. One goes back to the carb and the other to the flap in the inlet pipe where the preheat pipe comes from. It controls a flap so that warm air is sucked in from the exhaust manifold.
I'll follow your instructions and check the pipes, cheers.
'83 Mars Red 1.1 C
We turned it up, and it ran well, but was too rich (sooty spark-plugs and exhaust pipe-tip, bad MPG, and would have failed the next MOT), so the long term solution was to get the carb re-built - about ?100)
It might not be the cause of your problem, but get the mixture checked, to be sure.
The mixture should be 1.5% +/- .5% (VW spec). The MOT pass point for an early eighties car is 4.5% (unless it's changed recently).
'83 Mars Red 1.1 C
1983 1100 C
1983 1100 C
markwon said
Your carb should not be worn if only two years old. Do you know who fitted it? Quite possible carb wasn't fitted that well or they didn't use fresh gaskets.
No idea on either of those MW, i know the prev owner and he would definitly have paid a proper garage to do it. He said that the orig carb developed a hole in it and needed replacing, the only new carb he could get was the weber from GSF. He said that fuel economy was never quite as good after that .
'83 Mars Red 1.1 C
