stalling!
(In Topic #89443)
stalling!
1982 Golf 1.1 C
Anyone know how to stop bad luck?
1982 Golf 1.1 C
1982 Golf 1.1 C
Assuming everything else is OK with engine, timing Ok, points setup OK, clean fuel and air filters, plugs 'n leads OK, newish rotor arm 'n cap you can try and speed up the tickover a bit.
From memory if you stand infront of car looking at the carb from the right hand side. You should be able to see a large-ish straight slot screw in a sort of recessed hole. Turning this decreses or increses the idle speed.
Be warned though, messing with the carb before the ignition is sorted can cause more problems 8O
1982 Golf 1.1 C
1982 Golf 1.1 C
Web Team
1982 Golf 1.1 C
1982 Golf 1.1 C
No only kiddin mate, ur best bet is to just take it to a garage.
'83 1.5 Gx (picture coming soon)
1982 Golf 1.1 C
1982 Golf 1.1 C
