Screen wash bottle and connection on my 1.3 citi golf
(In Topic #84949)
i would like to get this back to normal, where can i get a new front bottle and motor from and how do i trace the wires from the stalk to make it work again?
many thanks
as standard the front bottle was wired (as you rightly said) to the pull operation on the right hand stalk and the rear bottle was operated with a push.
if the original wiring for the front bottle has been removed then for you to get it back to normal it requires this wiring to be replaced.
am i right or am i missing something…..
if im right il look at the haynes and tell you how to wire
right we need to check that they are the right ones - you could simply put them on your pump and try it but i would recomend a more scientific method…. easiest way is with a volt meter set to read 12volts ( maybe 0-20volt ) put it in series with the 2 wires you have found - switch the car to ignition live and try pulling on the right hand stalk - if this creates and voltage reading you have cracked it….
if you havent got a volt meter but you have a circuit tester ( dont know proper name but looks like a screw driver with a wire out of the handle and a buld in middle of the see through handle ) then clip the to 1 connector and probe the other with the driver head side and try the stalk again - hopefully the light bulb will come on…..
have you either of these?
I'll keep you updated!
this is incase they are both live or not even related to the same circuit - you dont want to short out any circuits.
maybe over causious but it is the best way -
keep me posted.
hope this helps
Thanks for the pre advice on this!
glad its all back to normal….
Many years ago before the internet, i change the entire fuel system on a mk2 digi gti, only to find out that the problem was the pump in the tank, which i never new existed!
