replaced rubber carb mount with aluminium/tuffnol
(In Topic #163982)
I thought i would share this
The old rubber carb mount on my car was perished and suspect, as in true DIY spirit (and had nothing else to do on the last day of term at college!) I set about making my own.
I used 6mm aluminium plate and tuffnol sheet with gaskets on all mating surfaces. Cut the gaskets on a laser cutter, and the tuffnol on a computer controlled engraving tool. Used a hole saw and files to create the centre hole in the aluminium and a jig saw and files to shape the outside.
The studs are stainless steel and made from m6 bolts with the heads cut off and ends tapped, held in with loctite.
Finished article:
I wouldn't advise making one like this, took too long plus too many surfaces to potentially leak. Was interesting though.
Rob
Robin
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
Don't think it is to prevent vibration, just to insulate from the heat, but may be completely wrong! I hope I am right…
