Questions on 1100 gg
(In Topic #140195)
i've some questions…
can i put polo head on this engine?
which cam shaft can I fit on the original head for more performance? (ex.. golf 1100 mk2, polo 86c)
Thanks!
looking at it i dont think the later heads would fit, but even if they did it probably wouldnt help much anyway as the small block heads all tend to be pretty much the same. it looks like the inlet is a different shape so this may not swap over either, so a later inlet might have to be bought. ideally a cam upgrade would get you more but im not sure what would be compatible and actually any better than what you have now.
personally i would leave it alone and save up for a complete engine change, maybe a 1.4 block from a mk3 golf and a polo gt cam, or for something a bit more beefy a 1.4 16v lump. all direct fit options
if it was me id be running the 8v lump on polo gt management, or the 16v on the polo stuff. but you could fit a carby from 1.3 mk1/2 or bike carbs if you fancied it. nice noise, not nice fuel consumption
megasquirt or similar aftermarket systems are an option too but more pricey to buy and have mapped.
you'll want a better carby when the 1.4 lump goes in so i think the inlet is going to have to be swapped regardless. same with the exhaust really but i recon the 1.1 system will fit. only thing is ton some theres a pipe from the exhaust to the inlet for aux heating or something? that can just be capped off wont be needed with the 1.3 inlet
