Porous head cylinder
(In Topic #212471)
I have coolant leaking issues potentially mitigated by last servicing repairs but I was advised that the cylinder heads are very porous and holed!
Just left a grand there
Has anyone tried to use K-Seal?
Golf 1.8 GTI Cabrio 1990
I had a leak on a Large engined Oldsmobile, and I used the Corvette Radiator Pellets. It saved me a replace the intake manifold gasket costs. I got the idea from my Brother who stated that GM is using these in all cars off the line to prevent itty-bitty leaks.
The questions is where is it leaking from? A outlet flange, a water pump, knowing where it is leaking effects the repair.
I have used Bars leak, before with fair results prior to getting parts together for a good repair.
Suspect its probably internal corrosion due to not maintaining the correct level of anti-freeze which contains corrosion inhibitors which for alloy heads is just as important as the anti-freeze bit.
In 60/70s when alloy heads were becoming common lots corroded and leaked or bunged up the cooling system leading to over heating when people ran them with old anti-freeze just plain water in summer which was no problem with 'tradition' cast iron blocks and heads.
Last edit: by Early-1800
Regards Volkswarren
& T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only) or an A reg Lhasa Green or White Gti to restore, also consider Black, Red or Blue, Project Wanted anything considered WHY
