Polo NZ injection setup
(In Topic #150240)
I know there are a few on here that have done the conversion so I would really appreciate the help guys.
So my questions are:
Fuel pump - Will I use the Polo NZ intank pump? I think its straight fit… is this true? And will I need to run another inline pump?
Wiring - Can I use the wiring from the Polo and does it just plug into the back of the mk1 (Series 2, CE1) fuse box? Or will I have to splice the old loom into the polo loom?
Exhaust manifold - Will the exhaust manifold from the mechanical head 1.1 fit the hydro head 1.3?
Coolant hoses - All should be a straight swap… shouldnt they?
And is there any other bits and bobs I should do while the engine is it? Its getting oil and a new filter (the engine had a new timing belt about 20k ago so thats cool)
Any help is appreciated folks.
Wiring - Not 100% but the ECU has its own loom I think? and the engine loom just needs a few wires lengthening.
Exhaust manifold - Will bolt up fine but the exhaust feed to the bottom of the carb will need welding up on the down pipe
Coolant hoses - are all pretty much a straight swap if you have S2 hoses.
The Mk1 Golfs older and better looking sibling……..
Ill have to get onto CP and get a GT pump sorted out. Have all the wiring here so just need to work it out.
